Old 06-10-2006, 03:36 PM
JavaDog's Avatar
JavaDog JavaDog is offline
JavaDog is on a distinguished road
Originally Posted by lerman
They claim to use standard components, pistons, rings, etc. Sure they do. You just take a standard piston and bend it so that it will fit inside a torus.
To make a standard cylinder, you just bore it and lap it. I can make a piston on my lathe. Then turn some grooves for piston rings. Or, I could cast the piston out of aluminum and then turn some slots for rings. That's not so easy with a curved piston.
Ken
Did you actually look at the patent? By standard components, they mean standard as far as production is concerned. Their piston isn't curved (well, the sides are just like on a "regular" piston). Again, I suggest you take the time to look over the diagrams in their forum, as well as the patents.
I don't know why people are so harsh about alternative designs for engines. Other than the really high HP/Torque claims, nothing else is all that crazy...
Check Out My Build-Log: http://www.cnczone.com/forums/showthread.php?t=6452
