Chris,
I've looked at your postp and it is the latest version so there shouldn't be any reason why you can't save multiple toolpaths (emd mills + Vbits + ball nose and engraving) into a single file.
I have sent you a VCW file that includes multiple toolpaths that can be saved using your postp. Important - You will see that you get an error message saying that VCarve 1 and 2D Machine 1 - both use the same tool number 1 - Because they have both ben calculated using Tool No. 1
If you edit one of these toolpaths to use for example Tool No. 6 - they can then all be saved into a single file.
Tony |
