Chris,
VCarve Wizard will save multiple toolpaths into a single file, so no need to do this manually. But this does depend upon having the latest postp installed.
Please e-mail the postp you are running to -
support@vectric.com
When each toolpath is calculated in VCW you need to ensure a different Tool Number is used for each cutter type used. Otherwise you will have V-Bits, Ends Mill etc all being set as Tool No. 1
Use the Toolpath List to switch on the toolpaths in the 3D window
On the Save Toolpath form select the
Output all visible toolpaths to one file
Very strange that toolpath - Mach3 Test 1.txt does not load - as this is the standard postprocessor that other users are running with Mach3?
For toolpath - Mach3 Test 2.txt it simply removed the header info from the file.
Send us your postp and we willl take a look
Tony
