Old 06-08-2006, 06:14 PM
dighsx dighsx is offline
dighsx is on a distinguished road
Chris can you post the code along with the crv file. I run Vcarve and Mach3 and haven't had this problem. Let me see if I've got the sequence right so I can try and recreate the problem on my setup.
You create a VCW file that has multiple toolpaths. You then save each toolpath as it's own gcode file. Then you load one file up in to Mach3 and cut it. Next you load another file up (and this is where you see problems) and you see that the tool isn't zeroed anymore?
A few questions: Are you changing tools between files? Do you use an offset when setting up your material in VCW? What post processor are you saving your files with in VCW?
Take it easy.
Jay (www.cncjay.com)
