OK. I'm not running a bar feeder from the spindle. I have a puller mounted on the turret, so there's no code to run a bar feeder. I just need code to to get the turret down to the stock, open the chuck, pull the stock and then clese the chuck. I have the code to get the turret down there, but then I get a fault. I might need the M31 int there I'm not sure. To get by I'm just using a square to set the stock out after each cycle. It works, but I have done the same thing on an American Way Lathe a |
