  #10
Old 06-05-2006, 08:00 PM
ger21's Avatar
ger21 ger21 is offline
Originally Posted by damae
What are the limitations of SheetCAM? For instance, I couldn't discern from the website if it has some limitation on the types of files it can import or if it can handle 3D contouring.
I haven't used SheetCAM since an early beta, but it's primary purpose is cutting 2D, or 2.5D parts. I don't believe it does any 3D contouring, but as was already mentioned, with some creative 2D drawings, you can create some 3D shapes by using a sewries of layered 2D toolpaths. As for file types, the most common it supports are HPGL and .dxf, but I believe it supports a few more 2D file formats. ASk in the SheetCAM forum, Les will usually reply pretty quick
I am worried that MeshCAM's waterline (z-level) machining generates the outline countour, but not the toolpaths to remove the material outside the outline.
Can anyone speak to these limitations?
As for MeshCAM, you remove all the material with the roughing toolpaths prior to running the waterline toolpaths.
