Old 06-02-2006, 12:40 PM
Shizzlemah Shizzlemah is offline
Shizzlemah is on a distinguished road
The I/Os are not a problem. If a parallel port is a turn off due to the limited number of I/O lines, you can easly add aditional ports.
Agreed that windows would NOT be a choice I would make. I havent looked at the EMC control for a while, but its very stable and linux based. Not to be confused with the clowny 'my first linux' offered by centroid, running their dos code (and it hicoughs and burps at differences between CR and LF)
As to the lack of home switches, some retrofits will only use a travel limit switch. They will cruise into the switch at a low speed, then back off until the encoder index pluse triggers. You can software define the coords around that point that triggers.
This system is decent for lathes where you can usually return to X+Z+ safely. No problem parking a lathe at that point. It's slow and awkward on mills to creep to X+Y+Z+. I like to park tables centered and supported, not all the way to the extreme of its travel.
If the ladder logic is done and working - and the servos and drives are happy - why not just bold on a 0T panel and call it a day ?
