Old 06-01-2006, 10:15 PM
lumberjack_jeff lumberjack_jeff is offline
lumberjack_jeff is on a distinguished road
4 x 8 router table
Newbie here. I have lurked the threads for awhile now and read all about your cool projects. First impression? "I'm not worthy".
I'm a mechanical engineer by training but I've found woodworking. Please tell me if I'm nuts:
I'd like to build a router table similar to the JGRO or Solsylva 25 x 35 table as a starter, then graduate to a bigger machine. The intent of the big machine is to cut out boat hull panels from 4 x 8 sheets of marine ply. In this application, accuracy is secondary to speed and economy. I expect that .010 - .015" tolerance would be precise enough. Also, I think that 75 ipm is the slowest practical cut rate for 3/8" ply. Back of the napkin calculations suggest that a panel could be cut up in about 8-10 minutes.
I've thorougly examined MadVac's pages and find that although his masterfully crafted machine is precisely the one I want, it's not necessarily the one I need, and truthfully, a guy's gotta know his limitations and it's unlikely that I'll be able to recreate what he built with my skills and in this lifetime. That said, I'm also not prepared to spend $30k+ for a turnkey system.
So, I'm wondering if anyone out there has built a somewhat quicker and dirtier version of a 4 x 8 gantry router? Any suggestions?
Maybe I should also consider a midrange 24 x 36 router table that will be accurate enough for precision work, and keep 'em both - because it's unlikely that I'll need to do both big and accurate.
Thanks in advance - and thanks for making this such an awesome board.
