A RAS is designed for the force/resistance to be in line with the arm, i.e. when you pull the saw thru lumber. With the saw not on, push it from the side, i.e. perpendicular to the blade when crosscutting. That's side load. I think the problem would be accuracy in that axis.
Phil |
