Hi Todd,
I've done some more testing and it appears the RESET needs to be pressed.
I have found that it wasn't the program getting run a second time which rectified the error, it was that I stopped the program and then pressed RESET.
1) No. 2) No. 3) No. 4) No. (I believe I have answered correctly?)
I ran in the Conversational Mode with No problem.
I changed the Radius in the Tool Table and the new figure was not read until I pressed RESET even after running more than once.
This is the procedure which I have been doing:
Standard MC Screen Operating Mode.
Tool in the spindle.
Press F1 (Tool Calibration)
Change 'R' Value.....ENTER.....ESC
SHIFT...ESC
EXECUTE
(Select PXXXXXXX).....ENTER
RUN (to end.)
The revised R value is not read.
SHIFT....ESC
Check the 'R' Value
Run a second time.....
SHIFT/ESC/EXECUTE/PXXXXXX/ENTER/RUN
The revised R value is still not read.
Pressing RESET updates the value but I see this as a bit of a trap.
Thank you for your help.
Kiwi |
