Old 05-31-2006, 08:11 AM
Al_The_Man's Avatar
Al_The_Man Al_The_Man is offline
The parts you describe would probabally need no conversion, IOW they should work at 240vac, you would need to find out how the low voltage is produced, usually through a switching supply to get the low voltage for the control logic etc. You could even hook it up to 240 1 phase and see if the logic and display come on as some switching supplies will operate over a wide range of voltages.
The Fan is usually fed from low voltage so check the voltage on that.
