On another note with the clearance for the bottom end you may have to go wider at the sump/block. A lot of engines are large in that area for the same reason. Just about impossible to keep it narrow using rods with capscrews to. If you look at a model rc engine or other type(weedwacker/chainsaw) they do not have bolts on the rods. They are full circle on the bottom.
John |
