I have a question regarding large DC power supplies.
I plan on utilizing a couple of the Rutex R2020 Servo Drives (200V/40A). I wonder, is one better off to build a power supply based on a large rectified toroidal isolation transformer in the 5 KVA range, or buy an off the shelf solid state Power module such as the Servo Dynamics 4017-PM which delivers 170VDC at 40Amps continuous, and up to 80 Amps for 2 seconds. The PM also includes an internal shunt regulator. The SD 4017-PM is small 7.6 in x 5.2 in x 2.7 in., and weighing in at only 3.8 lbs. Other than size what are the advantages and disadvantages of each type of power supply. Is one inherently safer than the other? I look forward to your response.
Thank you. |
