It seems that a rotary table is what is needed and probably wouldn't be feasible given the space constraints in the case. See to be quite a limiting factor though.
Given your current machine and the limitations that you have would you be able to recommend any others?
I know that I would like more power though for a deeper etching in some materiels.
Please describe the problems again with glass. Was it tempered? Did you pulse it to control heat, can you even do that?
Thanks,
Scott |
