What are your thoughts on counter-balancing the Z axis weight?
This would be a system in which the moving z-axis weight is counter-balanced by an equal weight placed on the opposite side of the gantry connected such that when the router moves up, the counter-weight moves down and vice-versa.
This can be accomplished via hydraulics, pulley system, or a constant force spring (
http://www.springcompany.com/jes2/cfframe/cf.html ).
I read that the HUGE boring mills...i.e. the 40,000 pound ones use a hydraulic counter-balance system to offset the wieght of their 100+ pound milling head.
What are the advantages and disadvantages to such a system?
This is what I can think of...(I of course could be wrong)
Advantages:
1. less wear on Z axis ball screws.
2. equal power required to move the z axis up vs down. Therefore, equal speed and acceleration potential for up vs down motion.
3. MORE???
Disadvantages:
1. Complexity of system...although a simple "constant-force spring" system can be devised.
2. Cost
3. MORE???
Thanks!
