For want of something better to do, I spent a few hours loading what I think is a bunch of common drill and tap data into the tool setup in Onecnc MillXPert. I also tweaked the nominal chiploads up to what I think is decent.
I've zipped the four files together since they are all shown as being modified at the same time stamp, although I think all you would need to use would be the one called
ncTools_inch.bin
There are three additional files that store some other user data:
ncCustoms.bin
ncMaterials_inch.bin
ncGlobal_inch.bin
Anyways, if you want to try this out, just back up your original files somewhere in case it doesn't work as you like, and you want to go back to what you had.
Disclaimer: the accuracy of the drill data is not guaranteed, but I did check it quite carefully. Please confirm whether the tool data you select is correct before jumping to conclusions and assuming it is correct.
