No....
The current will be 4.7 amps. The only way to make it draw less current is to supply it with less than the rated voltage. I don't think you want to do that.
Or, you could make it draw less regardless of voltage supplied by setting the current limit on let's say a xylotex driver at 2.5 amps. You will not get rated torque out then tho.
Those motors will need to be driven by a high current capable drive such as the Gecko 201 to make them put out max torque.
Eric
__________________ I wish it wouldn't crash. |
