Hello Bob,
One thing you can do to set scale is draw a square around your object. For example, if your encoder is basically a circle with a diameter of, say, 2" then you can enclose that in a 3" by 3" square. Then, after your conversion, you can use that box to crop the image, then scale to a 3" x 3" image.
Steve |
