NC Cams, you lost me on the last post.
Are you talking about the bearing blocks that the machined ends of the ballscrews fit into? What is a "quad" end bearing configuration?
Also, I'm a bit confused as to why you put particular emphasis on the end bearings. Aren't there a lot of other potential sources of error that are more significant? |
