I believe he is using two lead screws for the axis.
InventIt,
If you want to use transformers, you will need to rectify it and filter it. The DC that comes out is around 1.4 times the ac voltage. Two 24 volt transformers gives you 48 volts, rectified you will get ~70 volts DC. Perhaps you mean two 30 v RS powersupplies..
What's the motor voltage and amps? I would think you need one RS powersupply for each motor...at least.
Eric
__________________ I wish it wouldn't crash. |
