Old 12-02-2003, 06:18 PM
InventIt InventIt is offline
InventIt is on a distinguished road
pach rat:
The mounts for the motors are alum. and are bolted to 1/2" steel drilled and tapped plates that are welded to the corners of the frame.
balsaman:
--BTW, I enjoyed reading your buildups, nice job on your router(s)---
Yeh, so far the 1 amp has been doing the trick. But your right, I probably will have to upgrade. I may wire two 30v tranformers together in series to get 60volts and 1 amp. I need speed more than torque since I am only dragging a torch and not a pushing a router for now.
