Normally you use gear cutters, they come in sets of 8. The method gives "approaching" gears, they are noisy above a low (lowish) rpm. This method is inferior to the evolving milling method used in the making of industrial gears. I made several times a gear without a gear cutter, just by grinding the bit till it fitted in the tooth. Perfect? No. Every imperfection disturbs constant velocity and it will never wear in. But for low rpm replacements, why not?
Carel |
