Does it seem even seem remotely reasonable to use ONLY the 0 to 25 rpm range of your motor when you have a continuous 0 to 4200rpm motor speed range capability to work with???
The method (asside from the math) to determine the answer to your gearing question is outlined in post #6 above... |
