Rotery Table | | Vulcom1 Driled through the mountihg holes from the back side Ex. clearance for a 3/8 bolt through a 12mm threded hole this was on a larger chuck but scale it down 4mm or 10/32 or 1/4x20 through 6mm for instance or what ever size it takes you might have trouble finding T nut's for the thred size you need you may have to make them. Good luck Kevin |
