Hu and Rekd, Thanks for the responses.
Gave me a little food for thought. I hadn't considered using the G83 Peck Drilling cycle, seems like a good candidate.
What is L, W, X in these cycles?
Hu, I know you as the BOBCAD guru for the BC forum. I use BOBCAD V18. If I can't get one of these canned cycles to work could I commision you to write me a script to handle it??
DJ
REF:
G83 Normal Peck Drilling Canned Cycle Group 09
F Feed Rate
*I size of first cutting depth
*J amount to reduce cutting depth each pass
*K minimum depth of cut
*L Number of repeats
*P The dwell time at the bottom of the hole
*Q The cut-in value, always incremental
R Position of the R plane
*W Z-axis incremental distance
*X X-axis motion command
*Z Position of bottom of hole
G85 Boring Canned Cycle Group 09
F Feed Rate
*U X-axis incremental distance
* indicates optional |
