Both have demos. Try them and see which one works best for the type of work you plan on doing. Les will give you a 30 day code for SheetCAm if you ask him.(email)
Yes, Mach3 will create g-code from .dxf files. SheetCAM will give you much more control over the process. Also try out Mach3's new .dxf converter, LazyCAM. Free with Mach3.
__________________ Gerry
(Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
