It's here finally -
http://www.robgrz.com/download.phtml . By far the biggest release yet; something like 17 changes from the last version. The highlights are:
1) New stock dialog, much more flexible
2) Fixed bug where only flat end mills were used in calculations (Only a problem in Beta 9)
3) DXF support.
4) Ability to cancel long calculations
5) Lots of smaller changes requested by user is various forums.
The DXF importer seems to work well with the output from Rhino, but I'm sure many problems lurk. If you have a DXF file that doesn't work, let me know and I'll see if I can fix it.
Also, I've taken a beating in several newsgroups over my roughing algorithm with regard to the number of retracts it uses and my ego can't take it anymore. I've nearly completed a new roughing algorithm that allows an arbitrary stepover to be used and allows the user to select climb,conventional, or zigzag milling. This should be ready in about a week.
As always, let me know what you think,
Robert
