You may be right with the idea of pauses writen into the PLC. I do know with Mazak they do things a bit different for some reason. You woun't belive how hard it was to set up communication with the machine. In most cases you would set the DL softwear to the same parameters as the machine, but with Mazak the control and DL softwear are both set to different parameters in order to work.
Thanks for your help
Dan |
