I think I have finally got it!
It took a little work, but this nut will eliminate all Backlash from a Rolled Acme 1/2-10 threaded rod!
This is my first attempt, its big and bulky, and weighs over a pound!
I made is out of solid bearing bronze! In the future I plan on streamlining it to reduce the weight, and the diameter of the flange!
Has 4x 1/4" Dia. Holes on 1.875 Dia. Bolt Circle
OD=2.375" (Reduced to 1.375" Diameter)
Flange Thickness= 3/8"
Length= 1.875"
Weight=1lb 7oz
By turning the two #10-32 SHCS, this nut can be manually adjusted to remove backlash as the nut & screw wear from daily use!
Not sure if a grease nipple is necessary, but there is pleanty of room inside to hold a small quantity of grase!
I thought about using springs, but it didn't appear to need them!
Will make another nut with a 15/16-16 OD thread, like the ones on a Thompson ball nut, but not every DIY mechanic has a tap that size!
I have made a total of four nuts, using different materials such as: Delrin, Brass, Bronze, and Cast Iron. All are identical in size, but have different strengths and weights!
Here is the eBay listing!
Eric
