  #11   Ban this user!
Old 05-14-2006, 10:31 PM
zachjowi zachjowi is offline
zachjowi is on a distinguished road
Originally Posted by wizard
Not to be short here, but did you look up any of the addresses mentioned? Frankly you have left me confused about what you want. Further if you scroll down on the root menu page you will see a section call open source software. There you will find a thread on doing a grey scale to CNC conversion.
If you search around a bit you are likely to find other programs also.
As to the DXF conversion i have no idea why you would want to do that. To get the best develoment of G-code direct conversion is the answer. Even if by chance nothing you find on the net fits the bill as far as a G-code generator goes there is enough info out there that you could write your own. it is not a big deal.
dave
I can't write my own because I just started learning. I need this software to run on Linux and I know very little about Linux and how to install software on it.
