Old 05-10-2006, 11:04 PM
mikkojay's Avatar
mikkojay mikkojay is offline
Gold Member
mikkojay is on a distinguished road
Emco Compact5 Interface (like Weledit)
I am working on a program that is essentially like Welsoft's WelEdit. I recently bought an Emco Compact 5 and the DOS software did/does not cut it. I started reading about the serial settings & code formats, and it didn't sound like anything I had not done before. I was about 1/2 way done when I wandered across the Welsoft program online and I was shocked to see how similar it was to what I wanted, except for the fact that it costs nearly a hundred bucks.
I use the mscomm control to talk to com 1 at 300 baud. I used a listview control to keep track of the individual lines. I ended up using basically the same layout as the Welsoft program, except for mine is free! (and I can customize it however I want to!) If anyone is interested, I can send you a copy once I get it all tweaked out. I have successfully created, transferred, and run a simple program with it. This evening I was able to write a short program on the machine, then upload it to the program, and successfully save it to disk.
I'll attach a screenshot so you can see what it looks like.
If you have any questions or comments, please let me know.
Thanks, Mike
Expensive tools can be cheaper than professional therapy
