Old 11-25-2003, 11:04 PM
cwww cwww is offline
cwww is on a distinguished road
Originally posted by fjd
I had this problem once turned out to be bad break switch.
You mean the circuit breaker, or the fuse? Sorry I'm confused...
Originally posted by hardmill
Pull off the way covers and make sure its not loaded up
with chips. I've seen simular errors on other machines
and the problem was that simple. We had gone through
all the things that you are checking.
PEACE
Thanks for the suggestion.
I've already cleared up the chips under the way covers, but didn't help much... still the same problem...
I've changed the y-axis amp with another one, but same problem occurred, so the problem is not on the amp. Maybe I should swap the y-axis motor with the another one to see whether the problem's still there or not...
