I have never managed to remove a bend in threaded rod. The best thing is on picking the threaded rod from the shelf in the store roll it on the ground (hopefully it fairly flat). If the threaded rod is straight it will roll uniformly. If it is not straight you will see a high spot every turn.
Jason |
