Plastic pellets can react very violently under pressure and excessive heat, do you know what these pressures and heat thresholds are? If not, steer clear of messing around with these "chemicals". Being spattered with 400+ deg of sticky plastic will leave a mark! Have 30 + years as moldmaker/molder, you must always respect the high heats and pressures involved, they WILL react with no warning!! |
