Old 05-07-2006, 03:17 AM
c-c-cncboy c-c-cncboy is offline
c-c-cncboy is on a distinguished road
Smile Digitizing with output to file
Originally Posted by DennisCNC
Is there software available that will take input from two rotary encoders (X Y) and put point on the screen were ever you push a button to put a point. And output a DXF file?
Basicaly do what this thing does:
http://www.outlinetechnologies.com/index.html
Dennis: Check out if your CNC machine's controller supports G31. You're in luck if it does, cuz you simply command a move to the X,Y location and when you call G31... your controller will output the X,Y and the probe-sensed Z-coords. So your X,Y grid of commands will be turned into a "point cloud"
Regards,
Terrence
