p.s., Here's a sample of the formatting, taken from a
library that was converted to text. (The opposite of what you're doing.)
Code:
# TOOL LIBRARY FORMAT - Tue Jun 03 07:38:47 2003
# = comment if 1st character in line
# line 1 - TOOL (start of tool definition)
# line 2 - tool material (1-HSS, 2-CARBIDE, 3-COATED CAR, 4-CERAMIC, 5-BORZON, 10-UNKNOWN)
# line 3 - tool comment
# line 4 - tool name (geometry reference for backplot)
# line 5 - tool manufacturer
# line 6 - chuck designation
# line 7 - tool_no, tool_type, rad_type, dia, crad, thds, tip_angle,
# dia_off, len_off, feed, plunge, retract, rpm, coolant, n_flutes, bottom_turret, station
# line 8 - Drilling attributes (see tool_type in line 7 above)
# line 8 - cycle, peck1, peck2, peck_clr, chip_brk, dwell, shldr_angle, root_dia (tap), bore_shift
# line 8 - Milling attributes (see tool_type in line 7 above)
# line 8 - cut_able, rgh_x, rgh_z, fin_x, fin_z, tip_dia, root_dia (thd mill), thd_angle
# line 9 - pilot_dia, flute_len, oa_len, shldr_len, arbor_dia, hldr_dia, hldr_len, spindle_ccw, sfm, fpt, metric
# line 10 - Holder type, Work offset, Initial dir vector[3], Head offset[3], Tool offset[3]
# (tool types) (tool capabilities) (canned cycles)
# CENTER DRILL 1 ROUGH & FINISH 0 SIMPLE DRILL 0
# SPOT DRILL 2 ROUGH 1 PECK DRILL 1
# DRILL 3 FINISH 2 CHIP DRILL 2
# TAP-RH 4 TAP 3
# TAP-LH 5 (tool corner radius) BORE1 4
# REAMER 6 NONE 0 BORE2 5
# BORING BAR 7 CORNER 1 MISC1 6
# COUNTER BORE 8 FULL 2 MISC2 7
# COUNTER SINK 9
# END MILL FLAT 10 (coolant types)
# END MILL SPHER 11 OFF 0
# CHAMFER MILL 12 FLOOD 1
# FACE MILL 13 MIST 2
# SLOT MILL 14 TOOL 3
# CORNER RAD MILL 15
# DOVETAIL MILL 16 (spindle direction)
# TAPER MILL 17 CW 0
# LOLLIPOP MILL 18 CCW 1
# END MILL BULL 19
# BLOCK DRILL 20
# *** DO NOT REMOVE LINE NUMBERS OR DELETE ENTIRE LINES! ***
# *** ALL TOOL DEFINITIONS MUST CONTAIN 10 LINES AND THE 'TOOL' LABEL! ***
1 - TOOL
2 - 1
3 - 1/8 CENTERDRILL
4 - C:\MCAM91\MILL\TOOLS\CTRDRILL.MC9
5 -
6 -
7 - 1 1 0 0.125 0. 0. 90. 0 0 1.026816 1.026816 1.026816 2139 1 2 1 -1
8 - 0 0. 0. 20. 10. 0. 90. 0. 0.
9 - 0. 2. 3. 2.5 0.125 2. 1. 0 100. 12. 0
1 - TOOL
2 - 1
3 - 1/4 CENTERDRILL
5 -
6 -
7 - 2 1 0 0.25 0. 0. 90. 0 0 1.0696 1.0696 1.0696 1069 1 2 1 -1
9 - 0. 2. 3. 2.5 0.25 2. 1. 0 100. 25. 0
1 - TOOL
2 - 1
3 - 1/2 CENTERDRILL
5 -
6 -
7 - 3 1 0 0.5 0. 0. 90. 0 0 1.0696 1.0696 1.0696 534 1 2 1 -1
9 - 0. 2. 3. 2.5 0.5 2. 1. 0 100. 50. 0
1 - TOOL
2 - 1
3 - 1/8 SPOTDRILL
4 - C:\MCAM91\MILL\TOOLS\SPOTDRIL.MC9
5 -
6 -
7 - 4 2 0 0.125 0. 0. 90. 0 0 1.026816 1.026816 1.026816 2139 1 2 1 -1
'Rekd
