If you have set the current limit screw to match your motors you will be fine. I run three G320's on 10 amps on my drill/mill. Under normal use of the mill you will not be using very many amps per axis.
__________________ Thanks
Jeff Davis (HomeCNC)
http://www.homecnc.info
(Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
