I like to create a point at X0Y0, Then if you want to check another feature create a point in a position you want to check from' select every thing exept the two points and choose Copy/Move using the points to move from and to, then you can move the part back by reversing the process or even using the undo tab. It would be nice if Michael would step in here and explain "Move from In Car Position."
Ken |
