Old 04-26-2006, 08:40 AM
psychomill psychomill is offline
psychomill is on a distinguished road
Yes, you are correct. G68 is what you're looking for. Which version control do you have? G68 is an option (as it is with most controls of many makes). You can check if you have it by pressing " Diagnostics > Version > Option " on the control. If you see 'Rotation' (option #5 I think...) highlighted, then you have it installed. If you're unsure, just try the command on the machine. If you have it, it will work, ... if not, you'll probably get a "Mis-set G-code" alarm or something to that effect.
It's just a part..... cutter still goes round and round....
