Hey again Fyffe.
I found out that it jumps to local mode if the startpoint of the thing its gonna cut is outside the vinyl.
Flexisign has its own drivers, its not possible to install new ones.
I can only use "desktop printer" in the color printer mode of flexi, but then flexi thinks its a large colorprinter and it still dossent work.
When i go to WORD and type something and i press print with the correct vinyl size and so on typed in it cuts okay exept that it starts in center.
Do you use the RS2 setup in your F920 ?
is there any way to make a complete RESET of the 920 ?
The cable that came with plotter is the original. but i will check it. |
