Old 04-21-2006, 11:19 AM
BEDFORD BEDFORD is offline
BEDFORD is on a distinguished road
What do you guys use for acceleration settings in Mach 3 with the CNC kit from IH
I've been having issues getting the engine frequency, acceleration, and velocity set to the point where I can get repeatable movement. I'm running the demo version of Mach 3 demo version (25,000 Hz) on an 850 MHz P3 with the CNC kit from IH. I've managed to get it mainly working but while doing set-up for a bearing block I realized the holes I was milling weren't round they were more oval. I have since tried setting one drive and basing all other settings off of it (same ballscrews and encoders I should have done this sooner), but I will have it dialed in perfectly for one movement and then it will be off if I try and test it again.
Anyone know what might be going wrong?
James
Edit: If anyone has the proper numbers for steps on the encoders the ball screw threads and well while I'm at it the proper pulley diameters. With that I can calculate what the numbers should be and compare them to the auto set numbers).
