Originally Posted by paulC Mach software will not run on a slow machine. 1GHz processor is the recommended minimum platform. I have it running on a 600MHz PC (Although I wouldn't recommend this), but it would not run on a 300MHz machine. Gave similar symptoms to what you are getting, looked like it should be working but didn't.
Details of the OCX test is in the documentation and is used to test that you have the driver correctly installed and running. |
Ah. The compac is 533ghz with 1g ram. I'll take my 2ghz dell down there and hook that up to it and see if that works. The diagnostics show that the port is the right one and I set it up according to Campbell designs instuctions.
My initial thought was because the breakout board lit up as it should and the geckos lit up and the motors are getting current that it may just be some motor wiring I overlooked.
