if i understand you correctly i think that is what i am wanting to do. let me put ask it hopefully an easier way or at least the best way i can phrase it.
example:
fanuc is running a program and i need to index to a 30 degree rotation.
fanuc stops/pauses code execution
fanuc sends m code to mach3 setup
mach3 rotates rotary table x degrees
mach3 sends info back to fanuc to resume
fanuc resumes milling on new axis
end example
is this what would happen or the process that it would go through or am i off base?
thanks for the help |
