Old 04-15-2006, 12:30 PM
widgitmaster's Avatar
widgitmaster widgitmaster is offline
Gold Member
widgitmaster is on a distinguished road
Cool
Originally Posted by CLaNZeR
But that is not a bad idea, where would you get little rubber stoppers from?
Actually, it would be easier to make them yourself by mixing up some ReproRubber casting material, as it should follow the contour and not stick to the smooth surfaces!
http://www.smallparts.com/products/descriptions/rep.cfm
The taperd holes are easily made in a drill press, using a 1/8 tapered pipe reamer !
They can be found in hardware stores, or ordered online from Enco
Then you get a perfect seal!
Eric
www.widgitmaster.com
It's not what you take away, it's what you are left with that counts!
