Old 04-11-2006, 11:09 PM
Geof Geof is offline
It depends on your alloy and temper. With 6061 T6, which is the most common, you should be able to do 35 degrees over a bend radius about 1-1/2 to 2 times the material thickness. Other alloys or a lower temper will allow tighter bends but they are not as strong.
