I recently purchased two 200V, 40A Rutex servo drives. I am in the process of tuning the first one with my motor. I have a 500 line single ended encoder running in quadrature, and a 1/3 hp reliance electric motor (E675) rated for 100V running at 50V for tuning. I found a setting that looks good for very small step responses (650 Kp, 75 Kd, 2 Kdindex, 10 Ki, 50 steps). It also seems to work well for very slow rectangular or trapezoidal moves using the test sotware. However, I cannot seem to get it to run successfully for more than 50 steps for a step response, or for faster speeds on the rectangular or trapezoidal moves using the test software. Is there some kind of counter that is overflowing, or is my setting just unstable? Even at a conservative setting (no Ki, no Kd, low Kp) I cannot get a combination that will no run continuously at step responses greater than 100 steps or so. Anyone have any thoughts? Could the 50V (vs 100) be causing my problem?
-Brian |
