Thread: The basics
Old 04-10-2006, 02:07 PM
CJL5585 CJL5585 is offline
Gold Member
CJL5585 is on a distinguished road
Originally Posted by Netjams
Cad is the design software that is used to create the part.
Cam is the program that is used to create the machine code (Gcode).
Then you have the controller program that reads the Gcode and makes the machine run.
On things like cutting a picture into a part you can skip the Cad and import it direct into the Cam (if the cam supports this).
True
Computer Aided Manufacturing (CAM) is the function where a facility has all or most of it's machining functions run under centralized computer control.
A File Converter Program is NORMALLY used to convert CAD drawings to g-code. There are many file formats available for output from a CAD program. The standard output format is DXF (known as drawing exchange format) Such a program to convert this output is called DXF to G-Code converter
A free copy is available on this site under the download forum.
Can be called the Interpeter; Or, some call it the controller program
Jerry
