Konstantin,
If you have 19mm/revolution and use microstepping (10x), you will have 19/2000 mm/step. This amounts to .0095 mm/step, or .000374 inches per step. This seems like a reasonable distance per step. Depending upon your application's need for speed, a stepping rate of 25 KHz will result in a speed of 561 IPM; good for plasma use.
Regards,
Jack C. |
