Several things amaze me about the DIY CNC community.
1. People buy DIY electronic kits who don't know enough electronics to "do the math" when it comes to:
a. learning how to do basic calculations needed to construct power supplies, size resistors, figure out wire size, whatever. Simple basic "earth science" level math stuff.
b. Manufacturers make a sell kits that are poorly documented with recommended p/n's for the critical things need to make their kit work or to create what is needed to make it work.
c. anticipate that the DIY'er can't do even basic electronics design mods to adapt this into that... When you understand it, its simple, when you don't, it is like trying to read a foreign language.
d. Worse yet perhaps is that the manufacturers' engineers THINK for a minute that that the people will buy the kits are, first, educated enough to understand and do the math and, second, CAN and WILL take the time to do the math if they can.
If you make any of the above assumptions improperly, you are overestimating the technical skills and/or education level of your potential client base.
For those so inclinded, I've listed some links below that can be used by just about anyone who can "understand the math (wink wink" to size and create just about any size power supply that that they may need (if they pick the right components and proper sized transformer).
Linear P/S design/construction:
http://www.campbelldesigns.com/files...ply-part-1.pdf
Hmmm seems I already offered this hence I must be guilty of failing to consider assumption "d." above. How stooopid of me....
The other option is for the kit buyer to buy a P/S from the kit supplier in the first place. In that respect, the kit supplier should have pre-engineered one PROPERLY in anticipation of the less technically competent DIY'er when they decided to build and sell their DIY widget. If the mfg didn't engineer their DIY kit properly and/or failed to recommend an off the shelf P/S properly, they deserve whatever grief they get.
There's probably enough oversight to go around on both ends of the supplier chain in this instance - it usually works that way.
