Old 04-09-2006, 01:25 PM
One of Many One of Many is offline
One of Many is on a distinguished road
Originally Posted by Zumba
Lastly, are there any plans out there for building your own shop press? Grizzly has a 50 ton shop press for $600. Does the hydraulic ram actually have a 50 ton pushing capacity? Seems a bit far fetched. I'm looking at the Surplus Center website and the only cyclinder they have over 50 tons is an 8" bore double acting model for $1200.00.
The pump on these units are capable of 10,000 psi. If the cylinder were a 3.5" bore then it would take 10,400psi to get 50 tons. If it were a 4" bore cylinder, it would take 8000 psi.
The 8" cylinder would only take 2000 psi. Surface area becomes your mechanical advantage. That also requires addition strength in the materials used since the force acts on everything within the cylinder.
So, to answer you question. Yes, it may have a 50 ton capacity. Just by the skin of its little pump.
Compared to our Dake structurally. Anything near 50 ton on that frame looks scarey!
DC
Learn cause and effect through experience. Mastering those relationships is the "Common Sense" ability within the art of any trade.
